G'day Robin, as you would have gathered i took the pictures and Janie put them on here but for some reason she had great difficulty while i watched which to be honest is something she does not like
but i am only trying to learn which as you know is not easy for me.
I did have a sheet that showed me what to do stage by stage but then photo bucket went through a stage of being funny and i lost all that i had come to terms with all because of change
I will learn some how but Janie gets uptight when the computer does not do what she wants it to do otherwise you would have had pictures with more detail of the way i have made things fit and work by just using a bit of thought and remembering things like when i ran out of gas so i fitted a meths burner and the tank for that fuel is the lawn mower tank with a tap underneath
The fuel can carrier that is in the middle of the rear door is for my eberspacher red diesel heater again the red tank on the back on the offside is a tank off an outboard motor which is piped to the pump of the eberspacher and above that is where my gas bottle sits when it is folded down and part of that was from my first BSA C15 clutch push rod compressor.
Anyway enough for now before you get bored. Catch you later. R-Rose
