When extended the frame creates a roof area with centre ridge pole, which is ideal for throwing a tarp over either just as a roof, or over and down one side or even both sides if it's windy.
I'm sure most of you have seen pictures of them in use at shows etc. where we usually park back to back, but here are some pictures for those who haven't.
We tend to use cheap tarps, around £5 to £10 on ebay for one big enough to go over two Carawagons back to back with both awning poles extended, and down one side, but one of our members has had a copy of the original canvas awning made.
I have an original awning, but as we usually camp as a group, we tend to use the tarp as it gives a more communal feel.
In Morocco we used a thin cotton sheet over as a sun shade - the pink one in this pic!
The awning poles are self supporting and don't require any upright poles. They pull out around 2m, leaving about 700mm inside the roof for support.
The ones I intend making will be to the original spec, or as near as we can in this metric day and age!, and would be galvanised in one batch.
The only variation from original will be the supporting tubes inside the roof. Originally there was just a short length of tube inside to support the frame poles when pulled out, which meant when pushing the frame back in, they could catch on anything in the Carawagon roof pockets
These frames can be fitted to any 109", not just Carawagons, and a shorter version was an option on the 88" Searle Safari Sleeper (88" Carawagon) so there's no reason not to make them for SWB as well, if the demand is there.
I'll hold off ordering the materials for a couple of weeks to see if there's any more interest, but as the galvanising will have to be done as a batch to save costs, there has to be a cut-off point!
Costs are estimated at around £120 per frame, including the parts to fit the inside tubes.
DIY fitting is relatively easy, and I will supply instructions and measurements for the holes which need drilling, or if you fancy a trip over I'm sure we can come to some arrangement for fitting
Please PM me if interested.
