side awning on Dormobile
I saw a pictures in the last classic land rover magazine, a dormobile with a side awning on it. Is it someone from here?
Is it possible to have some picture on how it fit and how it's work with the lock system of the dormobile roof?
[img]Screenshot_2015-02-28-21-12-22.png[/img]
many thanks
Loïc
many thanks
Loïc
- Screenshot_2015-02-28-21-12-22.png (383.8 KiB) Viewed 19413 times
1957 S1 88"
1971 S2A Dormobile 6cyl
Re: side awning on Dormobile
Yes, it is mine mate. Pm me your details and I will tell you how to mount it. I designed a bracket that involves no drilling and is easy to fabricate. Dan
I fitted the front section of my awning to the roof rack and then made a stepped bracket which is fitted externally just behind the kitchen window. I put a metal plate on the inside of the vehicle and then bolted the bracket to the aluminium / plate, this gives a secure fitting. Make sure when fitting your awning to keep it parallel with the pop top roof and equal distance from the gutter
Mine is fitted probably 150mm higher than Dan's.
Thanks for your answer. For the moment I use a tap http://www.decathlon.be/tarp-kaki-id_2363223.html fixed with rope, but it is not quick and easy to erect. So I'm thinking about a side awning like ARB, maybe with a room under to put the stuff for the night
could you please put son detailed picture of the fixation? And on the place left for the roof's hook?
Loïc
Loïc
1957 S1 88"
Loic, send me your rmail address and I will give you details. My bracket design can be higher if needs be as it utilises the gutter (no drilling of vehicle) and has proven very robust.
Dan Could you possibly resend / cc me please? I have mislaid that which you sent me previously
MAny thanks
MAny thanks
Dan, if you the information on the bracket to hand it would be appreciated.
G.
G.
I have an 80s tastic frame tent available for modification.
I will see if I can find some pictures.
I broke my phone and cant get the data out.
I have awning rails screwed to both gutters so I can use our awning either side, The awning is a 2.8m Caravanstore and held up for transport with straps to keep it clear of the doors. If you are tall, this could be a problem, but not a problem to us average people.
Need to have a closer look at Dans truck to see how he did his, but our system works for us.
