I would appreciate your advice.
I have what appears to be a prior owner modification to the roof (as per images attached). On both sides a “rail” has been placed down the side of the roof.
It is starting to rust & I need to get it off, remove the rust, prepare & potentially refit.
1. What size foot fasteners did Dormobile use?
2. What material are they made from (brass)
3. Where do you suggest I source replacements for the non hinge & hinge side please? An enquiry has been sent to Dormobile direct in case they are willing to help.
If I do go ahead then gel coat will be disturbed. Do you offer a gel-coat repair “kit” as well?
The central internal lifting handle. Also rusted will undergo the same treatment.
4. What size & type (i.e material) of fasters were used originally for the lifting handle?
5. A well recommended supplier would be greatly welcome.
Please accept my apologies for the obvious questions.
