Expedition over-bonnet roof rack
Re: Expedition over-bonnet roof rack
Another dumb question if I may. How does the rack fit to the gutter rails (by clamps)?
Do I need to bring a drill to affix the front to the front bumper?
Already applying easing oil to the windscreen hinge bolts in preparation!
Looking at the images again it is bolted - so I will need to drill the roof gutter to affix - correct?
Still puzzled regarding the front bumper...
there is a possibility that I will be making a trip to Sheila in the next few weeks, with a trailer. If it helps, I can bring the roofrack back here?
From mine to Sheila is at least 6 hours .
It does look a heavy thing that you and Sheila would struggle with between you
regards
Alex
regards
Alex
Alex
Thank you for the offer.
If you could assist that would be very helpful indeed. However I would not want to impose on anyone.
That said, I would be highly appreciative.
Let us keep in touch & see what transpires in the meantime.
May I say a very big thank you to Sheila (Dieselhen) who offered huge hospitality on my trip up to collect the rack. I have not had such a wide ranging and enjoyable fireside chat like that for over 20 years.
The rack now is again in use...
May I also say a very big thank you to a gentlemen called Tam who assisted in fitting it so I could travel back down.
A wonderful trip. Terrific hospitality & a bit of UK motoring heritage back doing what it was designed to do. Modest rack adjustments will require it to come off again, be warmed up & refitted as the legs are 5 mm too wide for the guttering. That is a job for the future.
That is a serious roof rack! And a nice pair of sand ladders on the sides too?
Yes, I'm tempted once mine is fully on the road and kitted out. Need to check dimensions but a standard 88" rack might be the right size? Having had a look at Robin's Carawagon (and using him to mark the rack height) it shouldn't block the forward visibility too much either.
"Marque's Mobile Scaffolding".........
That certainly looks to be a heavy piece of equipment to haul around Marque, will you leave it on permanently or just fit it when you go travelling ?? I thought mine was quite heavy but that must weigh twice as much especially with the sand ladders fitted also.
Talking of scaffolding, I've been using mine as a mobile platform while I paint the house. A bit scary having the ladder fully extended sitting on the roof rack to reach the gables
Thank you Gentlemen
It took 3 to lift it on due to difficult size rather than weight. All up I would say it is 35KG. It will stay on permanently once the width issue is resolved. I intend to use it as a sun deck for the daughter & I on trips. It was an opportunistic purchase, hence the bulkhead is the next structural priority. Too good an opportunity to let go.
I will strip off the sand ladders & jerry can rack locking bar (not pictured) & put them out of harms way. The I will fasten seat belts & await SWMBO's wrath on her return after a month away. I do have alot of cleaning up to do. Off to do some now actually. Who would of thought Mr Muscle would be so useful ;-)
Land rovers are cheaper than marital guidance & a lot healthier too.
M
M
