Eddi
- Info: Carawagon Continental
Post
by Eddi » Sat Jun 13, 2015 8:25 pm
Good evening gents,
I need some help please, I stripped the woodwork off my series 2a station wagon a little while back to start refurbishing my vehicle. The company tasked with cutting new pieces closed doors last week and nobody seems to know where my sample pieces are.
Does anyone have drawings that may help in getting my vehicle back together ? PLEASE
KARL
chippit
Post
by chippit » Tue Jun 16, 2015 9:23 am
I am in the middle of putting the roof back together for a 109 1975 carawagon, I also bought a much earlier one to restore (approx.1968) they are quite different, you will need to measure the rectangular hole in the aluminium roof (the later one is at least 2"wider. Let me know, as I can easily sort you out some patterns.
Regards Christine
P.S where are you?
Eddi
Post
by Eddi » Tue Jun 16, 2015 10:46 pm
Hi Christine,
Will measure tomorrow, thanks so much !
Karl
Oh.....Johannesburg, South Africa
Calum
Post
by Calum » Tue Jun 16, 2015 11:44 pm
If it's the earlier roof I too have measurements I could draw up
Eddi
Post
by Eddi » Wed Jun 17, 2015 9:05 pm
Hi Christine and Calum,
My vehicle is a1968 station wagon, the rectangular cutout in the roof measures 2335mm x 1090mm. Hoping this helps.......
Thank you
Karl
- Carawagon
- image.jpg (49.68 KiB) Viewed 26336 times
chippit
Post
by chippit » Sat Jun 20, 2015 7:40 pm
Nice, I will measure my early roof tomorrow.
Christine
Eddi
Post
by Eddi » Sat Jun 20, 2015 8:02 pm
Thank you Christine,
No good news here, apparently all my original wood was thrown out when company closed down......
Karl
chippit
Post
by chippit » Fri Jul 03, 2015 6:18 pm
Sorry I have been a bit busy with work, when I get chance I will drawer round the curved ends to make a paper template with the measurements for the rectangular side pieces drawn on it. I will also measure the bendy aluminium section (this is very damaged on mine but O.K for dimensions), in fact I will do that next so you can check against your roof, hopefully they it will be the same as mine then I can post you the paper template.
Reagards Christine
P.S it may take a little time, we hire out narrowboats and it is our busy time of year.
Eddi
Post
by Eddi » Fri Jul 03, 2015 6:36 pm
Glad you're busy, must chat about using your services one day......... Often wanted to see England from the canals
Karl
chippit
Post
by chippit » Sun Jul 05, 2015 2:51 pm
Hi Karl,
The older bendy aluminium roof measures 2440 x 1500 I think this should be the same as yours. The later roof that I have from a 1975 landy measures 2440 x 1600. Hope this helps, by the way we are at Rose narrowboats, the heart of the canal system with a good choice of routes.
http://www.rose-narrowboats.co.uk
I think the carawagon is a fantastic design, such a simple idea and built by boat builders!
If the measurement of the ali roof is the same PM me your address and I will post a paper template.
Regards Christine
P.S. Does anyone know why the older roof has 4 large holes drilled in each corner of the bendy section? The later one does not have them.
