Time for another brew and a think before cracking on with the wires from the switches to the trigger terminals on the relays again checking my routing so it is at least neater than before after which with another brew it was test time with the avo on the relevant terminals that feed the cooling fan which also goes through a thermo coupling so i have the best of both worlds turning it on manually if the coupling breaks
My horns-dip and main beam go through separate relays as do my brake lights but the best one of all is my ignition switch to the coil so my starter dose not drain all the power from battery when firering here up.
Yes maybe i have made a rod for my own back but everything is done for a reason in my mind anyway just incase having been caught out in the past in different situations
Catch you later. R-Rose
