It's value to me is that of a decent shed! I'm looking for around £400
Cost about £1800 in materials to build
300tdi can pull it at 80mph and runs at 26mpg on a long run
It was designed to fit on a 110 or 109 chassis.
The sills, seatbelt pillars and roof, as well as the rear of the seatbox are all built in.
The roof could easily be changed for a boinger one though.
It's lined with 25mm of celotex and 4mm ply inside. Steel frame clad in Ali
The vehicle can be driven to be stripped of the body, or I can prepare it and you can come and lift it off. Will require machinery or alot of strong persons.
If you're interested let me know and we can start to chat!
