I have no idea!
Re: I have no idea!
Post by Dormy » Mon Mar 07, 2016 7:43 pm
Litelandy wrote:I did notice tonight that with the toolbox installed it doesn't leave much room for an overdrive! It'll be a hard choice
Not actually such an issue.
I have a Bearmach (Toro) overdrive fitted to Dormy. These come with an oil trap breather chamber as a top cover which I could see would definitely interfere with the bottom of the tool box. My answer was (after some careful measuring) to cut a couple of slots in the bottom of the storage box and bash that part until it was inverted. A couple of small aluminium plates were cut and riveted in to fill the gaps.
Result: - Overdrive fits without interfering with the box and I still have most of the capacity of the larger box (very necessary !).
Also, some self adhesive draft excluder across the back of the storage box seals the gap nicely.
