Carawagon?
dudley
Re: Carawagon?
Post by dudley » Tue Dec 04, 2012 8:06 pm
chassis good,panels straight
brakes binding,hubs ?,engine starts
owner very genuine and honest
phillip
Re: Carawagon?
Post by RobW » Tue Dec 04, 2012 8:25 pm
Cheers.
Re: Carawagon?
Post by RobW » Sat Dec 08, 2012 4:56 pm
Looks like it was a twin bed with the front seats folding down to make part of the bed. Units on both sides at the rear.
He's got it moving and fitted the replacement tyres brakes are knackered (ish) and hand brake will need checking. Just have to see who wins now!
Re: Carawagon?
Post by Dormy » Sun Dec 09, 2012 10:31 pm
RobW wrote:brakes are knackered (ish) and hand brake will need checking.
It's also got a Range Rover steering column and steering box - Best make sure the chassis has been properly strengthend around where they will have removed the front crossmember too.
Re: Carawagon?
Post by RobW » Mon Dec 10, 2012 7:50 pm
I'm sure the front cross member was still there? The PAS was off a Defender, surely it'd go through the same hole as the Series?
dudley
Re: Carawagon?
Post by dudley » Mon Dec 10, 2012 8:23 pm
the power steering was from a defender
and the cross member had been cut ,and a
smaller box section welded in,looked strong
enough
phillip
Re: Carawagon?
Post by RobW » Tue Dec 11, 2012 10:41 am
He's tubed the hole & braced it too - as Dudley says, it should be OK.
Info: Carawagon Junkie
Re: Carawagon?
Post by overlander » Wed Dec 12, 2012 11:11 am
An interesting vehicle which in my humble opinion can only go up in value. A great base to start from so bite the bullet guys, borrow from you kids or your Auntie, max out your credit cards and go for it - there couldn't be a better time for buying cheap. I shall be checking the final bid tonight
Good Luck
Re: Carawagon?
Post by RobW » Wed Dec 12, 2012 7:50 pm
Not buying this one then John? :neener:
Re: Carawagon?
Post by jerryd » Wed Dec 12, 2012 8:54 pm
Seems a bargain to me at the moment with 35 minutes to go :cheers:
