tuggy
- Info: 101 overlander
Post
by tuggy » Tue Feb 25, 2014 11:46 am
yea i cant put an exhaust on it as its 50mm it would be to low and you cant put a 90deg bend on because it will carbon up and cause back pressure so wont fire properly but i have been thinking and i am going to raise the unit in the box by fitting spacers under it raising it up...so the bottom of the exhaust is a couple of mm sticking out..
.will have a play with it today.....
tuggy
Post
by tuggy » Wed Feb 26, 2014 5:54 pm
got about 13 inches under the box but the exhaust looks like it could be damaged if it gets a bang so think i am going to raise the unit on pads so the exhaust just pokes through the box about 1-2mm them if i do clout something its not going to damage the unit... ..see how it goes.....
tuggy
Post
by tuggy » Wed Mar 05, 2014 10:15 am
ok had some time on the truck yesterday...I finished putting the new wiring in and rewired the interior lights also had a spare T MAX compressor so bolted that in the belly box and wired that in so i now have onboard air i might fit a small compressor tank in but thats more space i have to find and more weight..
.so might just stick with a long air line...
i moved the heater switch and mounted it under the seat locker so thats job done and it works very well.
then i built the box around the header tank so thats all safe now.. ...next job is to do the cab insulation keep watching this space... .
tuggy
Post
by tuggy » Wed Apr 02, 2014 11:28 am
Calum
Post
by Calum » Sun Apr 06, 2014 8:33 pm
Seems to take up a lot of space! In a 101", probably not much of a problem... what is the rated output of it?
Post
by RMS » Sun Apr 06, 2014 8:45 pm
Calum wrote:Seems to take up a lot of space! In a 101", probably not much of a problem... what is the rated output of it?
That heater unit is 4.6kW Calum.
See this post
HERE where I was considering importing a few - decided against the bigger one (the one tuggy has used) as it's just physically too big for those of us with smaller campers.
I'm in the final stages of negotiation for importing some of the 2kW kits though
Calum
Post
by Calum » Sun Apr 06, 2014 10:37 pm
Ouch. Think that'd be a bit too warm for me! I'll stick with my Propex
tuggy
Post
by tuggy » Mon Apr 14, 2014 9:46 am
