Ebay Carawagon £7.5k
Post by RMS » Tue Nov 12, 2013 9:55 pm
Just popped up on the saved search:
1968 Carawagon
6 pot engine, recent rear half chassis, engine and gearbox rebuilds (well, recent in LR terms :wink: )
No mention of condition of the roof woodwork, and as usual, no pictures of it erected (why do they do that :shrug: ).
Bereavement forces sale.
Classified ad (not auction) at £7.5k - we'll see how it goes :cheers:
Info: Carawagon Junkie
Re: Ebay Carawagon £7.5k
Post by overlander » Tue Nov 12, 2013 11:41 pm
Yes my attention drawn to this one earlier Robin - a fair price these days for a Landy that will only go up in value. Poor advert for a Motor Trader - a camper needs interior shots. Outside my budget though esp as it's a 6 pot petrol.
J
Calum
Post by Calum » Wed Nov 13, 2013 9:05 pm
Seems a sensible enough price to aim for I reckon... original, non-messed about with Carawagon with original engine and (what looks to be) paintwork/bodywork too. I have seen pics of this one on the net before and wondered if it did indeed have its 6 pot still installed - nice to see that it does :cheers:
Post by RMS » Sat Nov 16, 2013 1:23 am
Now includes interior pictures, and with the roof up, plus a whole lot more HERE
I like the tv cabinet :wink:
Calum
Post by Calum » Sat Nov 16, 2013 10:37 pm
VERY similar to mine in a lot of aspects! :cheers:
ADMIN EDIT due to RMS hitting the wrong button:
Quote by RMS:
"I did notice the aluminium frames for the windows in the roof section - I've only seen rubber mounted ones but remember you telling us about yours Callum.
Is the wooden frame on the inside part of the strengthening, or do you think a PO has added them for blinds or something?
Oh, and I like the letterboxes in the front of the roof - I assume they are speakers :shrug:
Robin."
Calum
Post by Calum » Sun Nov 17, 2013 1:01 am
You appear to have edited rather than quoted my post there, Robin!
Yes, the windows in the roof are the same as mine - Moydon frames like the side windows. I assume they must have changed not so long after '68 based on examples I have seen. Quite why, I don't know? cost? leaks? The actual window is Perspex in my roof, I would assume from new. The wood on the inside is simply there for the window frame to screw into, in the same manner as the side windows screw into the hard top sides. Mine has the same setup. The absence of any strengthening 'ribs' or angle is probably due to the larger windows having the aluminium frame which will add quite a bit of stiffness to the roof panel.
I can't say the speakers are a particularly elegant solution! I also assume that is what they are. The 240v sockets are hardly integrated into the fabric of the vehicle either... but I really like it! Nice motor.
Post by RMS » Sun Nov 17, 2013 9:55 am
:embarassed: Oops, really sorry Callum - that's what comes of doing things in a rush in the early hours of the morning and being logged in as an admin :embarassed:
I meant to hit 'Quote', hence the one line from your post :banghead:
Post by RMS » Sun Nov 17, 2013 10:08 am
The frame change to glass in rubber could have been a cost-saving exercise, though it could have been due to leaks :shrug:
It must be quicker and cheaper to fit rubber than the Moydon frame, and no screws etc. though as you say, the roof then needed strengthening ribs above the window, I assume to stop the glass popping out of the rubber when flexed!
Interestingly, one of the windows in mine is perspex, the other glass - either they were using up stock or it was replaced later due to breakage.
I must admit, after replacing the rubber seal on mine, I would have preferred the frame solution - the skin of the roof is so flexible it is really quite difficult to push the glass into the rubber, and is certainly not a one-man job :stars:
