Ablutions were admirably dealt with with a short handled ex military spade and some solitude (Apologies to the lobster boat on it's way back in on THAT morning BUT I truly expected the headland to be deserted
ANYWAY ....as part of the preparations for this years trip I intend to have fitted a pull out awning to the Foley roof rack AND a semi onboard shower system .....
My intention is to fit one of these diaphragm pumps with it's inbuilt pressure switch to stop the pump when the shower head flow switch is operated.
Into one of the rear wheel boxes and wired into the leisure battery
piped up to a couple of these bulkhead fittings....
Fitted with quick disconnect hose fittings to enable a supply pipe and a shower hose and head to be connected
And stuck to a suitable smooth surface with one of these ...
I'm intending to line a small ammo tin with 1/2" copper tube salvaged from work to provide a heat exchanger that will sit on top of the coleman petrol cooker that always travels with us ....
The base cut out and replaced with mesh to allow storage of shower head and hoses inside to keep it all tidy .
IF anyone is interested I'll update things as I get a bit further on (As soon as my Manflu lurgy clears )
I've already done the ebay hard work lol
