new roof
new roof
Well, after a lot of research and some vital information from the learned gentleman, I have sourced all the parts to totally rebuild the roof. Now comes the difficult bit...
Re: new roof
What? Stopping Helen from showing you how it is done?Now comes the difficult bit...
Re: new roof
Hi Dave,
Glad to hear that
What sheet material are you using?
Is the weekend camp at your place going to be a "roof raising" celebration?
Glad to hear that
Re: new roof
That's a good idea!RMS wrote:Is the weekend camp at your place going to be a "roof raising" celebration?
Re: new roof
Materials sourced so far are...
US 2024-T3 ALCLAD ( uk L109) Aluminium Sheet. This is a close as you'll get to Duralinium®. £239.
Continuous aluminium hinges from Häfele. £35
Sheet of 12mm exterior ply wood void free £27
Sheet of 18mm exterior plywood void free £40
Rubber from COH bains IRS0668EP, IRS0564EP, IRS0693EP, IRS0326EP, flat rubber strip 50mmx1.6mm £135
Flock and adhesive from FLOCK-KING. £95
OUCH!
I've still to get screws paint and varnish as well as new roof to side panel and windscreen seals
Not Cheap!
OUCH!
Not Cheap!
Re: new roof
OUCH!
Not Cheap!
OUCH!
Not Cheap!
Re: new roof
Have fun with the flocking Dave
I've seen the kit Steve got - probably the same as yours with a puffer ball? Looks like hard work!
We had a guy came up to us at the Ripon show a couple of years ago - said he worked for Searle and it was a horrible job which they used to get paid extra for.
I suppose they would have used compressed air though - probably a lot faster and easier, but also probably a lot of fibres floating in the air.
Don't forget pictures, especially the flocking procedure
Re: new roof
I will be applying it electrostatically
Re: new roof
Does this mean holding your fingers in a wallsocket while doing it???bigdave wrote:I will be applying it electrostatically
What does this Flocking entail though? Is this some sort of insulation in the roof?
Re: new roof
Basically its the original finish. Have a look on YouTube, there a quite a few how to guides on there that should give you an idea of the process.
